6 Replies Latest reply on Sep 19, 2014 8:02 AM by Thomas Granzow
    VBA runtime error when using PDM checkIn function
    Thomas Granzow
      So im trying to write a makro to automate the name generation and the check in to the pdm Vault. The makro works fine to the point where the checkIn function is used.
      I get the runtime error´-2147220968 (80040218)
      There is no valid client license on this machine
      The manual check in works fine and i can delete files from the fault via API.
        • Re: VBA runtime error when using PDM checkIn function
          Deepak Gupta
          Kindly share the complete macro OR codes to debug.
              Thomas Granzow
              Dim myPDMConn As New PDMWorks.PDMWConnection
              Dim myProperty As PDMWorks.PDMWProperties
              Dim myProperties As IPDMWProperties
              Dim myPDMWSearchOptions As PDMWorks.PDMWSearchOptions
              Dim mySearchCriteria As PDMWorks.PDMWSearchCriteria
              Dim results As PDMWorks.PDMWSearchResults
              Dim result As PDMWorks.PDMWSearchResult
              Dim andOr As PDMWorks.PDMWAndOr
              Dim propertyTypeName As PDMWPropertyType
              Dim propertyTypeRev As PDMWPropertyType
              Dim condition As PDMWConditionType
              Dim myDoc As PDMWDocument
              'Testbereich-------------------------------------------------------------------
              Dim slwLink As Object
              Dim currentPart As Object
              Dim longstatus As LongLong, longwarnings As LongLong
              Dim saveOptions As swSaveAsOptions_e
              Dim saveErrors As swFileSaveError_e
              Dim saveWarnings As swFileSaveWarning_e
              Dim filename As String
              Dim project As String
              'Dim partNumber As String
              'Dim Description As String
              'Dim note As String
              Dim i_revOption As PDMWRevisionOptionType
              'Dim Revision As String
              'Dim lifecycle As String
              Dim RetainOwnership As Boolean
              'Dim References As Object
              Dim checkInReturnValue As PDMWorks.PDMWDocument
              Dim returnValueDelete As Integer
              Dim deleteString As String
              Dim value As Long
              Dim valueCount As Long
              Dim hey As String
              Dim Number As Long
              Dim cnt As Long
              Dim strDocName As String
              Sub Main()
              'Variablendeklaration-------------------------------------------------------------------
                  andOr = pdmwAnd
                  propertyTypeName = pdmwDocumentName
                  propertyTypeRev = pdmwRevision
                  condition = pdmwContains
                  saveOptions = swSaveAsOptions_Silent
                  saveErrors = swFileNameEmpty
                  saveWarnings = swFileSaveWarning_NeedsRebuild
                  i_recOption = Default
                  Set slwLink = Application.SldWorks
                  Set currentPart = slwLink.ActiveDoc
                  Set myPDMConn = CreateObject("PDMWorks.PDMWConnection")
              'Verbindungsaufbau zum Tresor-------------------------------------------------------------------
                  myPDMConn.Login "admin", "adminPW", "server"
                  myPDMConn.Refresh
              'Suchoptionen-------------------------------------------------------------------
                  Set myPDMWSearchOptions = myPDMConn.GetSearchOptionsObject
                  If Not myPDMWSearchOptions Is Nothing Then
                      myPDMWSearchOptions.IgnoreCase = True
                      myPDMWSearchOptions.IgnoreLinks = False
                      myPDMWSearchOptions.IncludeHiddenDocuments = True
                      myPDMWSearchOptions.SearchConfigSpecificProperties = False
                      myPDMWSearchOptions.SearchOnlyChildrenOf = ""
                      myPDMWSearchOptions.SearchCriteria.AddCriteria andOr, propertyTypeName, "", condition, "sldprt"
                      myPDMWSearchOptions.SearchCriteria.AddCriteria andOr, propertyTypeRev, "", condition, "00"
                      myPDMWSearchOptions.SearchCriteria.SaveToFile "P:\MedFact Standard Blattformate\Makros\cri_test.sqy"
                      myPDMWSearchOptions.SearchCriteria.LoadFromFile "P:\MedFact Standard Blattformate\Makros\cri_test.sqy"
              'Erhalten und auswerten der Ergebnisse-------------------------------------------------------------------
                  myPDMConn.Refresh
                      Set results = myPDMConn.Search(myPDMWSearchOptions)
                      If Not results Is Nothing Then
                          cnt = results.Count
              'Speichername mit Counter zuweisen und Dokument schließen-------------------------------------------------------------------
                      cnt = cnt + 1
                      filename = "P:\Endodrill II\" & cnt & ".SLDPRT"
                      longstatus = currentPart.Extension.SaveAs(filename, 0, saveOptions, Nothing, saveErrors, saveWarnings)
                      slwLink.QuitDoc currentPart.GetTitle
              'Einchecken in die Vault-------------------------------------------------------------------
                      'deleteString = cnt & ".SLDPRT"
                      myPDMConn.Refresh
                      'returnValueDelete = myPDMConn.DeleteDocument(deleteString)
                      Set checkInReturnValue = myPDMConn.CheckIn(filename, "sample", "1001", "sample prt", "Check in via API", PDMWRevisionOptionType.Default, "00", "WIP", False, Nothing)
                  myPDMConn.Logout
              Santosh Pawar
              Hi Thomas,
              Modify the path environment variable to include C:\Program Files\Common Files\SolidWorks Shared, restart the machine.
              Take a look at the pdf attached to last post at following link for details,
              https://forum.solidworks.com/message/213534?sr=search&searchId=ac009a42-d82d-4007-a1ff-cc5c93a100b7&searchIndex=1#213534
