i encounter the missing segment during flatten route. there are segment of the routes missing. Does any one know the cause and have any solution to this problem. without showing all the route segment, i will not be able to generate a correct drawing. see below on missing segment.
happens in routing from time to time especially if you changing route diameters within one route.
try to change length and rebuild, then come back to editing route and change length back to original dimension.
regards,
Tomasz
