Im not sure how to even explain this problem that I am having but Ill give it a go. This is happening frequently and is absolutely maddening!
Im using SW 2011 x64 SP4.0
This happens when I work in an assembly. I will select two or more parts and one of two things happens. Either the computer hangs for a long time between component selects or, more recently, my excel will flash up on the screen multiple times! I have been able to see the file that is being opened and it is the 'custom properties' template.
Also, in case it makes a difference, I am noticing that my RAM usage is at 9.25 out of 12 available.
Does anyone have any idea of whats going on here?
Let me know if I did not present enough information and I will get you whatever you need.
Thank you,
-Nick
