I have a quick question, I have been researching this for quite some time now and cannot seem to figure out a solution. Here is my situation:
I am working with solidworks 2014 and have my own personal default templates set and configured just how I need them and they work fine, I know how to set different templates, choose the default template locations, etc. My issue is that a lot of the parts I work with come from Germany (or even just another engineer at my location) and these parts obviously have their own defaults templates applied (which do not match across all the parts I receive and definitely do not match the templates that I have/need to use) and I cannot for the life of me figure out (or even know if it is possible or not) how to force these parts/assemblies to open with my default template settings. Is there an option that I am missing somewhere? Or would this require some sort of a macro function to be created/run at the opening of each part/assembly?
Any and all input will be greatly appreciated.
Thank you,
Roman
Roman,
There isn't a way to open existing files using your templates, that is why you haven't been able to find much on it . What you will need to do is open your template(s) and export the Drafting Standard from the "Document Properties" options tab. Then you will need to open the part(s)/assembly(ies)/drawing(s) in question, select the "Load From External File.." button found where you exported your settings files, select the appropriate one, and then it will appear with all your document properties applied.
Paul
