When populating my drawing with views,the flat pattern does not unfold.
I have had this issue with SW 2014.Checked the Property manager,and it shows the flat pattern as the selected view.
Still,all the rebuilding and control q I try no unfolding is performed.Open the part and it unfolds fine.
If I leave it in the flat pattern,my formed views are incorrect???? It is designed in a top down assy that has many other references,so leaving it unfolded disrupts the design intent.
Anyone else have this problem with SW 2014 SP2?
Try making your own flat pattern configuration and using that in your flat views.
There is a difference between "Unfold" and "Flat Pattern". Sometimes an Unfold feature will work but the Flat Pattern will have difficulty. Be sure to check the actual Flat Pattern feature by unsuppressing it in the model.
