Hi
Can someone tel me how to convert pro e files to solid works files...
Hi
Hi Damodaran,
As Ian mentioned, you will be needing the Solidworks Pro or Premium to run an Add-in "Feature Works".
I have used it quite a lot for my work, but please note that Feature Works can help in recognizing most of the Solid Features it may not be very competent in recognizing surface features.
If you can share a file , I might be able to help you out.
regards
Rohit
is there any software which can convert pro e files to solidworks files without changing into imported model?
yeah Eddy i'm able to see all those tabs which you mentioned in earlier chat but still my part is in imported i want it to be feature body.
please help me out
Also, what version of Solidworks are you using?
and is it a standard, professional or premium version?
I've tried importing your file as described above, but the result is only on imported body.
Your only option is to use featureworks to get the features you want.
Eddy
is there any software which can convert pro e to solidwork files, because i have some assemblies to convert
Your not going to get the file to come in as native and your definitely not going to bring the tree from Creo/ProE in. Your best bet is to find someone to do your work within Pro E or manage with dumb solids as imported. Featureworks is only going to recognize basic and mostly simple features, it's not going to pull anything wild in by any means.
Just go to File > open and select the pro e file :
Good luck!
Eddy
