when i cut "CFDRDDWR Head Jamb" with a simple triagnle but with option "Normal to cut ", i got error
Question asked by Ahmed Lasheen on Sep 15, 2014
Latest reply on Sep 28, 2014 by Ahmed Lasheen
Dears I need your support in the below problem.
kindly find attached pictures of problem i faced.
-for the attached sheetmetal part I have to do 45 degree triangle cut at both sides for fixing with other sheetmetal frames
-when i cut "CFDRDDWR Head Jamb" with a simple triagnle but with option "Normal to cut " , i got error ,i tried to look for workaround to overcome the error :-
1-if i modified the triangle like pic 3 i got no error. (we can use it as temporary solution)
2-if i did the cut for similar part CFDRDD Head Jamb i got no error "kindly check the difference" (we can't use it as i did modification in design)
