I like to use section view to check my model. E.g to see whether I have made holes for screws
My assembly model is large. Every time I want to focus on a small part using section view. I see that I can move the section plane, but the control arrow is far way the part that I want to view. I need to move my cursor away the holes that I am focusing on, and then find the section view arrow (which is far away), then move the section view arrow from there. Since it is far away from my part, it will make a big cross movement even if I do a small move in my cursor. How to solve it? Please help
OK
rmb means right mouse button
Press and hold the control key and select a face on each of the parts that you want to isolate. release the control key
right click on one of the faces and from the drop down menu select isolate
You will now just have the 3 parts showing. You will now be able to use the section view tool to create your section view.
When you are finished viewing the parts click on Exit Isolate to go back to viewing the full assembly
If you only want to isolate one part just right click on a face of the part and then select isolate from the drop down menu.
