2 Replies Latest reply on Sep 15, 2014 8:44 AM by Jesse Seger
    How to get the confignuration name in feature tree?
    Yong Ning
      follow code → result → Part1-1
      Help me
      Hope get configuration name p2
      Private Sub llll()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
          Set SwApp = Application.SldWorks
          Set SwModel = SwApp.ActiveDoc
          Debug.Print SwModel.GetTitle
          Set swSelMgr = SwModel.SelectionManager
          Dim SwComp As Component2
          Set SwComp = swSelMgr.GetSelectedObjectsComponent(1)
          Set swFeat = SwModel.FeatureByName(SwComp.Name2)
          Debug.Print swFeat.Name
          Stop
        • Re: How to get the confignuration name in feature tree?
          Rushabh Shah
          Hi Yong,
          saw your files, hoping to learn something, but these is dangerous coding, especially for a novice like me .
          - sorry, but i dont answer to your problem.
          - but for curiosity, isn't in your assembly file, you need to 'activate configuration' as required ? because from image of assembly, 'p2' configuration is active.
          - also, when running your macro, it gives error of not find project library, see image below.
          - if you have, references of excel, from, TOOLS -> References -> selecting excel type library. Than i suggest that, you add reference programmatically, so as, other people working on your macro doesn't need to add references manually, i am also learning and working on this same concept.
          - Also, which Sub to run ? or am i getting this whole thing wrong ??
            Jesse Seger
            I added a line below to get the referenced config.
            Private Sub llll()
                Set SwSelMgr = SwModel.SelectionManager
                Set SwComp = SwSelMgr.GetSelectedObjectsComponent(1)
                Set SwFeat = SwModel.FeatureByName(SwComp.Name2)
                Debug.Print SwFeat.Name
                '************ Add this line to get referenced config
                Debug.Print SwComp.ReferencedConfiguration
                Stop
            Maybe you want to set the config??  It's hard to tell from your questions, but below is an example of that too.
            Private Sub llll()
                '************** Add this if you want to set the config
                SwComp.ReferencedConfiguration = "p2"
                Stop
