Macro to make stl and igs parts of model starting from drawing file
Question asked by Ted Wayne on Sep 12, 2014
Latest reply on Sep 18, 2014 by Ted Wayne
At work we have been having problems with keeping our revisions in line with all of our files. Our drawing templates are set up so the most recent revision in the revision box on the title block links back to the custom properties. I have managed to find macros online and modify them to help with our problem. right now i have one that takes the revision off the drawing file, adds it to the end of the model file name, and saves it as a .STEP file. I want to do this with .igs and .stl files also but i cannot seem to get it to work. This is what i have for step files.
*I am fairly new to Macros, but i have a decent understanding of programing
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swCustProp      As CustomPropertyManager
Dim valOut          As String
Dim resolvedValOut  As String
Dim Filepath        As String
Dim FileName        As String
Dim retVal          As Boolean
Dim errors          As Long, warnings As Long
Set swDraw = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
  1. swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
' If no model currently loaded, then exitExit Sub End If Set swView = swDraw.GetFirstViewSet swView = swView.GetNextViewSet swModel = swView.ReferencedDocumentSet Sheet = swApp.ActiveDoc.GetCurrentSheet  Set swCustProp = swDraw.Extension.CustomPropertyManager("")
  1. swCustProp.Get2 "Revision", valOut, resolvedValOut 'Change the custom property name here
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
FileName = Left(swModel.GetTitle, Len(swModel.GetTitle) - 7)
'change the step file options
retVal = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swStepAP, 214)
'save
retVal = swModel.Extension.SaveAs(Filepath & FileName & "REV" & resolvedValOut & ".step", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, errors, warnings)
