3 Replies Latest reply on Sep 15, 2014 5:17 AM by Deepak Gupta
    Modify macro to work in SolidWorks drawing
    Feroz Mahomed
      How can I modify the code below to work in a SolidWorks drawing instead of a part?
      Sub Main()
      Set CurrentDoc = swApp.ActiveDoc
      Set Part = swApp.ActiveDoc
      ' No document loaded error handler
        If Part Is Nothing Then
            MsgBox "No document loaded!", vbCritical
            End
        Else
      Part.ClearSelection2 True
      ' Assign custom properties
        PropName(0) = "Die Number"
        PropName(1) = "Plant"
        PropName(2) = "File Name"
        PropName(3) = "Press"
        PropName(4) = "Drawn Date"
        PropName(5) = "Del Date"
        PropName(6) = "Bolster"
        PropName(7) = "Cavities"
      ' Add custom properties (won't overwrite if they already exist)
        Prop = CurrentDoc.AddCustomInfo3("", PropName(0), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(1), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(2), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(3), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(4), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(5), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(6), swCustomInfoText, " ")
        Prop = CurrentDoc.AddCustomInfo3("", PropName(7), swCustomInfoText, " ")
      Call CheckProps
        • Re: Modify macro to work in SolidWorks drawing
          Deepak Gupta
          Here are the updated codes
          Option Explicit
          Dim Part As ModelDoc2
          Dim PropName(8) As String
          Dim Prop As Boolean
          Sub Main()
          'Set CurrentDoc = swApp.ActiveDoc 'Not sure why you have this line when next line does the same thing
                End
            Else
            Prop = Part.AddCustomInfo2(PropName(0), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(1), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(2), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(3), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(4), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(5), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(6), swCustomInfoText, " ")
            Prop = Part.AddCustomInfo2(PropName(7), swCustomInfoText, " ")
          Call CheckProps
