3 Replies Latest reply on Sep 12, 2014 11:17 AM by Jesse Seger
    Applying name to all faces when revolve contains split sketch
    Suraj Khosla
      I am trying to assign a name to all faces on parts, I found an example which does exactly this:
      Option Explicit
      Dim Part As SldWorks.ModelDoc2
      Dim boolstatus As Boolean
      Sub setFaceNames()
      Dim swFace As SldWorks.Face2
      Dim currface As Integer
      Dim retval As Variant
      Dim i As Integer
      Dim obj As Object
          If Not swApp Is Nothing Then
                  Set Part = swApp.ActiveDoc
              If Not Part Is Nothing Then
                  Set swPart = Part
                  If Not swPart Is Nothing Then
                      retval = swPart.GetBodies2(SwConst.swSolidBody, True)
                      For i = 0 To UBound(retval)
                          Set swFace = retval(i).GetFirstFace
                          currface = 1
                          Do While Not swFace Is Nothing
                              swFace.Select False
                              Set obj = Part.SelectionManager.GetSelectedObject5(1)
                              boolstatus = swPart.SetEntityName(swFace, currface)
                              Debug.Print swPart.GetEntityName(swFace)
                              Set swFace = swFace.GetNextFace
                              currface = currface + 1
                          Loop
                      Next i
          Set swApp = Nothing
      This has worked fine for most of the parts however, there is one component which is revolved as two separate closed sketches as shown below:
      This causes problems as the faces on the left section of the revolved body do not seem to get names applied to them, only the faces on for the section sketched on the right do. I think this may have something to do with the split between two sketches resulting in SW thinking these are two separate bodies?? In which case, how could all faces be named?
          • Re: Applying name to all faces when revolve contains split sketch
            Suraj Khosla
            Please see attached file, macro has been ran on this and can be seen only one half of the model has names applied to the faces.
                Jesse Seger
                Ok I found the issue.  Found this in the help file.
                "If the entity already has a name, then this method does not change the name and returns false.
                This behavior is intended to prevent a program from accidentally renaming an entity that is referenced in some other location. For example, if an assembly contains a mate to a face on a part, then a name is automatically assigned to that face. If you were to change that name, then there is no guarantee that the mate is still valid. Therefore, when using entity names, you should first check to see if the entity is already named, and, if so, use the existing name. If no name exists for the entity, then you can name the entity.
                You can explicitly delete an entity name using the IPartDoc::DeleteEntityName or IPartDoc::IDeleteEntityName method. You then have the option of renaming the item or using that name elsewhere. The method was provided because the action is already available in the core SolidWorks product. However, you should recognize the possibility of reference failures as described."
                The reason it wasn't working on your two body part was that your currface = 1 was in the body loop thus resetting it to 1 after it looped through the first body.  So the entity name was already taken.  I added a line to delete the name.  See the comments below.
                Here is the updated macro.
                Option Explicit
                Sub setFaceNames()
                    Dim i As Integer
                    Dim obj As Object
                            Set swPart = Part
                            currface = 1
                                    Dim swBody As Body2
                                    Set swBody = retval(i)
                                    Debug.Print swBody.Name
                                    Set swFace = swBody.GetFirstFace
                                        swFace.Select False
                                        boolstatus = swPart.DeleteEntityName(swFace)   '************************  remove or comment out if you don't want to accidentally rename your faces in the future.
                                        Debug.Print boolstatus & " " & swPart.GetEntityName(swFace)
                                    Loop
                                Next i
                    Set swApp = Nothing
