Hello - I am trying to sweep a simple rectangle along a 2D centerline sketch, which is on a plane 15 degrees off perpendicular.
As per picture below, when I do the sweep the shape twists at the vertical leg, even though I have selected normal to profile.
Can anyone tell me how to correct this?
You might need to model each leg separately and then loft in between for the bend.
