Simple Animation Question.
I am trying to move a part off a assembly , I set up the move for 4 seconds , move the part, works fine, but when I play it back in the time bar nothing happens to the part until the last few seconds then it jumps to the end point. Its not a smooth move just stays in place till the end then jumps to new position. In the assembly it was mated to the surface , but I suppressed it in the animator , would this have an effect?
does the workflow work in other models? (just to make sure your method is sound)
it sounds like you may have a key in between the 2 final steps
