8 Replies Latest reply on Jun 10, 2015 3:49 AM by Greg Hynd
    What's the deal with Solidworks MBD?
    Kevin De Smet
      So I've been reading about this new product that Solidworks will offer called "Solidworks MBD" and that it'll be around two thousand dollars.
      I am wondering if anybody can tell me how this will be different from DimXpert and the use of Annotation Views as we can, today.
        • Re: What's the deal with Solidworks MBD?
          Paul Salvador
          and,... why do we have to pay for it?
            Paul Cullen
            Hi Kevin
            I saw a demo of MBD at SWW 2015. It has more functionality than DimXpert. In MBD you create views such as front, top, right, isometric or any other view that you want. You then export your information to a PDF file.
            When you open the pdf file in Adobe Viewer you can then either view the part in 3D or you can select each of the views that you have generated to view them. There is also a way to embed a file such as the part file or a dumb solid of the part into the pdf so as when you send the pdf to the workshop floor they will have the correct solid model to go along with the pdf. You can set up your company title block or any other notes so as they also show up in the pdf and you can also show all necessary tolerances etc. There is probably some more functionality that I have forgotten.
            If I worked in a cnc machine shop I would definately be looking into the MBD option as the cost of the licence should easily pay for itself if you currently spend a lot of time creating drawings for machined parts. I find that to do fully details drawings of parts takes as long to do as to create the 3D model itself, therefore if I could cut down on the amount of time I spend creating drawings that means that I can spend more time creating 3D models and get more done.
            If you are interested you should contact your VAR and see it they can set up a 30 day trial for you.
            Paul Cullen
              Jeff Holliday
              I have seen it demonstrated several times and although I can see benefits in using it, I am not too sure that the cost will be palatable to many smaller users. My first reaction was, like you Kevin, that some of that functionality is already present. I applaud SW for moving the process forward but I think there would another way to accomplish it and likely increase the "bottom line" even more. If SW were to offer it at a much lower price (even free, included with the Software) it could be used as a major bonus for choosing SW. At $2000, it is yet another "add on" which we used to love about Pro-E modules.
