I am having issues with the circular pattern command. I have created several parts over the last couple weeks without any issues, but all of a sudden I am getting an error (geometry pattern results in disjoint bodies) Is this a software problem or something in the settings? I have not changed anything about the procedures I use to create my parts.
If you're patterning bodies, then are you selecting "Bodies to Pattern", or "Features to Pattern"? If you are patterning bodies, then you need to select "Bodies to Pattern". If that's not it, can you post the part that's causing the problem?
