User has a problem following a crash - the top menu bar is missing?!?!
Toggling the pin doesn't recover it. please see attached. I'd rather not have to re-install if anyone can help first.
Have tried Customize->reset etc. no joy.
Thank you.
Phil Lane.
Philip,
Try resetting your registry for SolidWorks. You will lose all your other personal settings but should get your menu back. Try using the "Copy Settings Wizard" before resetting the registry & then restore settings after resetting registry. Hopefully this will retain all your other personal settings but not bring but the menu issue.
Follow instructions on the folowing posts:
icons not apperaing in my sw 2014 sp1
Resetting the SOLIDWORKS registry
