I would like to be able to draw a single line in a sketch, create a structural member from that sketch and then use that part as if it were not a weldment at all. That way, if I later decide I need to change the material, I can enter the feature properties of the structural member and select a different material from the list and have the properties from the new weldment profile dynamically update in an excel BOM. I hope this is clear but I can do what I can to clarify if anyone has questions. Thanks!
Not too sure what you're asking. However it sounds more like a straight forward component that uses the weldment method to produce the body.
You can select the body in the FM and mark for non-inclusion in the cutlist. All the properties can than be specified as normal custom properties.
The part could be set a normal welement part and the cutlist information could be ignored.
Roy.
