I have a table sort of structure made out of angle. The corners of the top sections are mitered with the legs extending down at the corners. Rather than the legs being flat and butting up against the corner, the filleted portion of the leg continues to extend up to the top inner part of top angle. See picture for reference. I can't seem to use the trim feature to fix this. I know I can manually do a cut-extrude, but this seems like something the weldment feature should be able to accomplish. Am I missing something? Or do I just have to take care of it with a cut-extrude?
I think you should be able to use the Trim function to trim the leg, and choose the bottom surface of one of the horizontal pieces for it to Trim/Extend to.
