Is it possible to display a reference geometry (axis, plane) but not its name? In other words, Can I hide the name of plane or axis?
Thanks Kevin,
I had the idea and renamed it "1", but the dot is a good idea too.
Our shop is opening the cad file with eDrawing and they need to see an axis. The only way I found to enable that is if I show the axis in Solidworks and save it. Great, you see the axis in eDrawing, but you also see its name and its written BIG! It overlaps the cad actually.
Greg,
Thanks for your input. I checked the "Hide Names" option but it made no difference. Neither did changing the font or the size in the option below that, nothing altered.
Kevin, I was reading thru this post (How do I hide or remove these while I do wire routing?) and I found out that one need to set this option for individual component. So did you tried doing that?
Not that I know of, although you could change the name to something less obtrusive like a dot, comma or colon, or a single letter or number.
Why do you need to?
