I am hoping there is a way to find entities by name in a sketch. For example, a line might be referenced in a feature as 'Line9 in Sketch10'. Are there other ways to identify the names of entities?
That is a big help Jamil! I did not know about that (probably been seeing it but not registering). Are there other techniques to see for instance a list of all entities?
If you select a group of entities, or even do ctrl+a to select everything, then it shows a list of the entities on the left side in the Properties area.
If you select one of them in the list then it makes that entity thicker in the graphics area.
If you right click on the entity, then it will show the name in the menu next to Selected Entity.
