TMTore Magne Bjornodegard04/09/2014
I have made macro to make it easier and faster to set scale to my drawing views. Works by selecting view you want to scale and starting sub ScaleUp or ScaleDown, if no view is selected sheet scale is set either up or down. Simple as that.
'QuickScale By Tore Magne Bjørnødegård
'If view is selected:
'Selected view is set to use "custom scale", and scaled up or down.
'If no view is selected:
'"sheet scale" is scaled up or down.
'Feel free to do the changes You like.
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swSelMgr        As SldWorks.SelectionMgr
Dim swView          As SldWorks.View
Dim Part            As DrawingDoc
Dim currentSheet    As Sheet
Dim vScaleRatio     As Variant
Dim boolstatus      As Boolean
Dim ScaleBy         As Integer
Sub ScaleUp()
ScaleBy = 1
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    If swSelMgr.GetSelectedObjectType2(1) = 12 Then
        Call SetViewScale
    Else
        Call SetSheetScale
Sub ScaleDown()
ScaleBy = -1
        Call SetViewScale
    Else
        Call SetSheetScale
Sub SetSheetScale()
    Set Part = swApp.ActiveDoc
    Set currentSheet = Part.GetCurrentSheet
    vScaleRatio = currentSheet.GetProperties
    'Debug.Print ("Scale = " & vScaleRatio(2) & " : " & vScaleRatio(3))
    If vScaleRatio(3) >= 30 Then
        ScaleBy = ScaleBy * 10
    ElseIf vScaleRatio(3) >= 10 Then
        ScaleBy = ScaleBy * 5
    If vScaleRatio(2) = vScaleRatio(3) Then
        If ScaleBy > 0 Then
            boolstatus = currentSheet.SetScale((vScaleRatio(2) + ScaleBy), vScaleRatio(3), True, False)
        Else
            boolstatus = currentSheet.SetScale(vScaleRatio(2), (vScaleRatio(3) - ScaleBy), True, False)
    ElseIf vScaleRatio(2) < vScaleRatio(3) Then
    ElseIf vScaleRatio(2) > vScaleRatio(3) Then
Sub SetViewScale()
    Set swView = swSelMgr.GetSelectedObject5(1)
    vScaleRatio = swView.ScaleRatio
    'Debug.Print ("Scale = " & vScaleRatio(0) & " : " & vScaleRatio(1))
        If vScaleRatio(1) >= 30 Then
    ElseIf vScaleRatio(1) >= 10 Then
    If vScaleRatio(0) = vScaleRatio(1) Then
        If ScaleBy > 0 Then
            swView.ScaleDecimal = (vScaleRatio(0) + ScaleBy) / vScaleRatio(1)
        Else
            swView.ScaleDecimal = vScaleRatio(0) / (vScaleRatio(1) - ScaleBy)
    ElseIf vScaleRatio(0) < vScaleRatio(1) Then
    ElseIf vScaleRatio(0) > vScaleRatio(1) Then
    boolstatus = swModel.EditRebuild
