Please let me know how to eliminate the trailing zeroes in the weight and length column after the decimal.If not length, atleast the weight.It looks odd.
Example: In the weight column of Item no:1 the value is 3573.051251366 and the unit is in gram. I want it to be 3.6 kilogram as the unit . How do I do that?
Please find the attachment for clarity.
Check your unit settings for both Basic Units and Mass/Section Properties. If even you've the correct decimal place plus trailing zeroes have been defined, then please report this to you VAR with the files as this is a bug per SW KB (SPR 197999 )
