I have this assembly I created for a Triclamp sight glass, but it needs bolts to run between the two flanges.
I know I could draw the bolts or use the toolbox, except I'm not quite sure how to use the toolbox to give me the bolts I need.
The physical part itself uses a rod that's threaded on both ends and bolted down with cap nuts.
Could someone be so kind as to show me how to use the toolbox or point me to a tutorial of some kind on it's basic use?
Assuming you've used the hole wizard to create your holes, you'll click on the 'Smart Fasteners' button on the assembly tab in the assembly. Define your needs and accept.
However, I'm not sure that Toolbox has threaded rods. If I were you, I'd got to McMaster-Carr and get the models you need from there.
