28 Replies Latest reply on Dec 1, 2017 1:54 PM by Jennifer Farrar
    Template Switch Macro - Multisheet, Multiple Sizes
    Elizabeth Levasseur
      Hello.  I am trying to use a macro written by Lenny Kikstra (ages ago) to change the sheet formats of a lot of drawings.  The drawings are a collection of A, B, C, or D sized drawings, and some are multi-sheet with a different format beyond sheet one.  So, this Template Switch macro seems the perfect fit for the job.  However, it starts with the drawing that is open, produces a pop-up box that you need to choose which format to use for the first sheet, changes it, then gets stuck,  (I suspect this has to do with Solidworks changes over the years since this macro was written.)
      I believe with some adjustment to the macro code, this will likely work very well for me.  But I don't know how to get it there.  (I did already modify the .ini file to point to the right formats.)
      HELP?  (Macro attached)
      Thank you,
      -Beth
