Hi all -
I have a cylindrical ring which I have projected a vertical rectangle on to create a split line feature. What I am trying to achieve is to replicate this feature 6 more times to create a radial pattern on my ring but this feature doesn't seem to work with the split line command. Do I need to create a separate plane | sketch for each instance to be able to project this onto my ring body?
It seems like there should be an easier way to do this. I've attached a screen shot of the part where you can see (in blue) the split line I am trying to pattern.
Thank you.
L
One thing you could do is use the original rectangle sketch to extrude a surface through the face you are splitting. Then circular pattern that surface body around the part, and finally use all of those new surface bodies to make intersection split lines on the face.
