hello, i'm a student studing
trying to get mould for my part at 1 degree, can some one have a look at my part tell me whats wrong
i have tried useing draft to make positive and negative drafts
wont let me shut off surface for the hole
is parting line ment to auto work out, its not working
Alex
hi,
your part is quite badly formed. if you are learning mold design, I suggest you skip this component for the present.
instead focus on the mold design steps and then come back to this component later.
the part requires to be repaired, some faces deleted and adjusted, a hollow thru opening has to be deleted etc.
see the file attached
