I have created a part and threaded each end according to 6 5/8" API Regular Left Hand thread specifications. I attempted adding a fillet to both crest edges of the threads on one end of the part with one fillet feature and received a rebuild error. I then applied the fillet to only one edge and received no error, so I created a second fillet for the other edge and still no error. Strangely, when adding the fillet to the threads on the opposite end of the part with the same geometry I am able to re-use the first fillet feature for the corresponding edge with no error. However, if I use the second fillet for its corresponding edge at the other end, I recieve a rebuild error. I even tried making a third fillet for the remaining edge and still get the error. It seems that this error is only present intermittently as I have created similar threads on other parts with no errors at all using only one fillet, and somtimes I will get this error when I first try to fillet and on later attempts I won't. Thanks in advance for any help.
Andrew,
It could have something to do with the way the fillet ends on one end or the other. Or it may just be that fillets are a bit touchy. I haven't noticed it in a while, but back in the good old days I had lots of trouble with fillets that wouldn't pattern, fillets that wouldn't mirror, fillets that worked if you started them on one end but not the other, fillets that worked if you selected some of the edges without tangent propagation and then made another fillet of the same value for the rest of the edges, fillets where a variable radius with all the same value worked when a constant radius wouldn't...
Jerry S.
