I am looking for a macro that will allow me to select a specific cut-list in my part, and modify the cut-list properties of the selected cut-list. As an example, with Cut-List1 selected, the macro would edit the Cut-list properties to alter the description property and add the Length property. The values of the properties would be then cut and paste from existing properties such as bounding box width and bounding box length would be copy and pasted into the length property together.
Here is a basic start. Run the macro after selecting a cut list folder. It will print the name of the folder in the immediate window, assign the description custom property value to a string variable, print that to the immediate window, and add a new custom property "Length" whose value will be the same as the description.
