hello,
i have a problem with this sketch :
so i want the pipeline follow the blue line to have one inlet on the left and two outlets toward the bottom.. but i'm not able to make it! i want the join is done automatically for the outlet in the middle (if its possible)
which toolcan i use?
thank you
I can think of hand of several possible ways to do it.
The question is though what are the limitations that you need or want it to adhere to?
For instance, why not use a sweep for the middle outlet combined with a cut-extrudes to make it fit snug to the pipe as well as create the oblong hole in the pipe?
