I imported a parisold into solidworks as a sheet metal part. I added a sketch pattern and I tried to change the 5.63 dimension on the base flange sketch. It will not let me change that dimension. What might be wrong?
When a sketch contains a lot of entities, SolidWorks turns off Automatic Solve, so that when you change a dimension it doesn't show you the change until you rebuild. To force it back on go to Tools > Sketch Settings and then enable Automatic Solve.
