Hello, I'm trying to cut a thread so the end of the top end of the thread tapers off as if it has been cut using a die. If I use a simple helix and the swept cut command the thread finishes with a square end.
Is there a way of creating a helix that finishes with a straight line coming off at a tangent as this should create the right appearance?
You can make a variable pitch helix wit a section at the end that increases in diameter until the threads no longer cut. If you have SW2014 you can look at my example model.
