Good morning everyone!
I sketched on the front plane.
Now I have no idea how I am able to put the hole on the top of that??
I am still confused about the advantage of Convert Entities?
And I do not know what's wrong with the third image. What is the usefulness of creating a plane in Insert/Reference Geometry?
Every feedback is much appreciated!
If you've already created the sketch to put the hole at the top of the body, and closed it (so the sketch is no longer active), right-click on the sketch and choose the "Edit Sketch Plane" icon. Then select the Top Plane. After doing this you may need to edit the sketch since some relations may be lost. The plane used for a feature sketch doesn't need to be in contact with the cut, so the Top Plane can be used. After moving and editing the sketch you can select it and use it for an Extruded Cut, choosing "Through All" for the End Condition.
If you just want to create a plane directly at the top of the part, then activate the command, as in your third screenshot, choosing the curved surface for Tangent, then select the Top Plane for the Second Reference and set it to Parallel.
