1 Reply Latest reply on Feb 26, 2015 10:52 PM by Yong Ning
    Design table → Browse to locate the table with API
    Yong Ning
      Hope use API finish
      From file. References a Microsoft Excel table. Click Browse to locate the table.
        • Re: Design table → Browse to locate the table with API
          Yong Ning
          Find method
          ' Preconditions: Part or assembly document is open and contains a design table.
          ' Postconditions: None
          Option Explicit
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc
              Dim swDesTable              As SldWorks.DesignTable
              Dim nTotRow                 As Long
              Dim nTotCol                 As Long
              Dim sRowStr                 As String
              Dim i                       As Long
              Dim j                       As Long
              Dim bRet                    As Boolean
              Set swModel = swApp.ActiveDoc
              Set swDesTable = swModel.GetDesignTable
              bRet = swDesTable.Attach
              Debug.Assert bRet
              nTotRow = swDesTable.GetTotalRowCount
              nTotCol = swDesTable.GetTotalColumnCount
              Debug.Print "File = " & swModel.GetPathName
              Debug.Print "  Title        = " & swDesTable.GetTitle
              Debug.Print "  Row          = " & swDesTable.GetRowCount
              Debug.Print "  Col          = " & swDesTable.GetColumnCount
              Debug.Print "  TotRow       = " & nTotRow
              Debug.Print "  TotCol       = " & nTotCol
              Debug.Print "  VisRow       = " & swDesTable.GetVisibleRowCount
              Debug.Print "  VisCol       = " & swDesTable.GetVisibleColumnCount
              Debug.Print ""
              For i = 0 To nTotRow
                  sRowStr = "  |"
                  For j = 0 To nTotCol
                      sRowStr = sRowStr + swDesTable.GetEntryText(i, j) + "|"
                  Next j
                  Debug.Print sRowStr
              Next i
              swDesTable.Detach
          Function MassAndMaterialRng(SwModel As ModelDoc2, TitleRng As Range, Rng As Range)
             Dim Sht As Worksheet, Str, Row, Col
               Set Sht = Rng.Parent
             Dim cMassRng As Range, MassRng As Range, MatRng As Range
               Set cMassRng = TitleRng.Find("质量")
               Set MassRng = TitleRng.Find("mass")
               Set MatRng = TitleRng.Find("Material")
               For ii = 1 To Rng.Rows.Count
                 Row = Rng(ii, 1).Row
                 Str = Rng(ii, 1) & "@" & SwModel.GetTitle
                 If Not cMassRng Is Nothing Then
                    Debug.Print Sht.Cells(Row, cMassRng.Column).Address,
                    Sht.Cells(Row, cMassRng.Column) = """" & "SW-Mass@@" & Str & """"
                 If Not MassRng Is Nothing Then
                    Sht.Cells(Row, MassRng.Column) = """" & "SW-Mass@@" & Str & """"
                 If Not MatRng Is Nothing Then
                    Debug.Print Sht.Cells(Row, MatRng.Column).Address
                    Sht.Cells(Row, MatRng.Column) = """" & "SW-Material@@" & Str & """"
              Next ii
              'Stop
          End Function
          Function delDesign(SwModel As ModelDoc2)
             Dim SwFeat As Feature
                Set SwFeat = SwModel.FirstFeature
                Do While Not SwFeat Is Nothing
                   'Debug.Print SwFeat.Name, SwFeat.GetTypeName
                   If SwFeat.GetTypeName = "DesignTableFeature" Then
                     SwFeat.Select True
                     SwModel.EditDelete
                     Exit Do
                   Set SwFeat = SwFeat.GetNextFeature
                Loop
             Dim ConfArr, SwConf As Configuration
                ConfArr = SwModel.GetConfigurationNames
                Set SwConf = SwModel.GetConfigurationByName(ConfArr(0))
                SwModel.ShowConfiguration2 SwConf.Name
                For ii = 1 To UBound(ConfArr)
                   'Set SwConf = SwModel.GetConfigurationByName(ConfArr(ii))
                   SwModel.DeleteConfiguration2 ConfArr(ii)
                   'Stop
                Next ii
          End Function
          Function TwoRngInsertDesign(SwModel As ModelDoc2, TitleRng As Range, Rng As Range)
              ''汉字处理
              Dim Str, MassRng As Range, MaterialRng As Range
                 Set MassRng = TitleRng.Find("@质量")
                 Set MaterialRng = TitleRng.Find("材料")
                 Str = Chr(34) & "SW-Mass@@" & Rng(ii, 1) & "@" & SwModel.GetTitle & Chr(34)
                 Rng(ii, MassRng.Column) = Str
                 Str = Chr(34) & "SW-Material@@" & Rng(ii, 1) & "@" & SwModel.GetTitle & Chr(34)
                 Rng(ii, MaterialRng.Column) = Str
              Next ii
            Dim Wk As Workbook
              SwModel.InsertFamilyTableNew
            Dim SwOleObj As SwOLEObject, vOle, Vv As Long
              vOle = SwModel.Extension.GetOLEObjects(Vv)
              Set SwOleObj = vOle(1)
              Set Wk = SwOleObj.SetActive(True)
              TitleRng.Copy
              With Wk.Sheets(1).Range("A2")
                     .PasteSpecial xlPasteValues
                     .PasteSpecial xlPasteFormats
                     .PasteSpecial xlPasteColumnWidths
              End With
              Rng.Copy
              With Wk.Sheets(1).Range("A3")
              End With
              SwOleObj.SetActive False
            Dim SwDesgTab As SldWorks.DesignTable
              Set SwDesgTab = SwModel.GetDesignTable
              SwDesgTab.Attach
              SwModel.CloseFamilyTable
                 'Debug.Print SwModel.CustomInfo2(Rng(ii, 1), "质量"),
                 'Debug.Print SwModel.GetCustomInfoValue(Rng(ii, 1), "质量"),
                 Rng(ii, MassRng.Column) = SwModel.GetCustomInfoValue(Rng(ii, 1), "质量")
                 Rng(ii, MaterialRng.Column) = SwModel.GetCustomInfoValue(Rng(ii, 1), "材料")
              Next ii
          End Function
          Sub deldel()
            Dim Xls As Excel.Application
              Set Xls = GetObject(, "Excel.Application")
            Dim Sht As Worksheet, Rng As Range, TitleRng As Range
              Set Rng = Xls.Selection
              With Sht
                 Set TitleRng = .Range(.Cells(2, 1), .Cells(2, Rng.Columns.Count))
              End With
             Dim SwModel As ModelDoc2
                Set SwModel = Application.SldWorks.ActiveDoc
                delDesign SwModel
                TwoRngInsertDesign SwModel, TitleRng, Rng
