6 Replies Latest reply on Aug 28, 2014 9:24 PM by Deepak Gupta
    How to make a message to the user: "Please first save the file." in VBA macro?
    Bobo Zhelev
      I have a question concerning the following simple macro. Macro is used to convert PDF files into solidvorks document. Macro works fine, but if the file is not saved shows an error message. I would like if the file is not saved to show a message to the user: "Please first save the file." After recording the macro file to continue.
      Thanks in advance for your help.
      Dim swModel As ModelDoc2
      Dim lErrors As Long
      Dim lWarnings As Long
      Dim FileName As Variant
      Dim Path As String
      Set swModel = swApp.ActiveDoc
      If swModel Is Nothing Then
          MsgBox "Please first open solidvorks file."
          Exit Sub
      Dim exportData As SldWorks.ExportPdfData: Set exportData = swApp.GetExportFileData(swExportPdfData)
      exportData.ExportAs3D = True
      Path = "D:\"
      FileName = swModel.GetTitle
      FileName = Left(FileName, Len(FileName) - 7)
      FileName = Path & FileName & ".pdf"
      swModel.Extension.SaveAs FileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, exportData, lErrors, lWarnings
