So I've been using SW Electrical for a week now and have managed to make some custom components, associate them appropriately, and wire them in SWE 2D. I just tried to open the project in SWE 3D for the first time last night and ran into an issue. The first two custom components I tried to insert did so successfully and without issue, the last which was also a round barrel shape connector (as opposed to the first two which were square connectors) would not insert and the following error message would appear:
"The 3D part associated to the component could not be used. Reason: the manufacturer part dimensions are less than the minimum dimensions of the part.
Height: 37
Depth: 35
Check manufacturer part dimensions, some could have been switched (width and depth for example) or are missing."
I have changed the dimensions in the manufacturer properties several times and even modified the part several times in an attempt to correct this issue but have been unsuccessful. Does anyone know a solution to this issue? Thanks
I've run into this issue as well. Usually it is when we are creating dynamically resizable parts, that some pattern or something has a minimum size that it can be. But often we have to just start the part over when we get the error, because nothing we change will make it go away.
I created a test part that was just a 2mm cube. I assigned it to a solidworks Electrical part that had dimensions set to be 40x50x60. It inserted just fine with no problems. I also set the solidworks Electrical part to be .5x.5x.5, and it inserted without error.
Do you want to attach the problem 3D part, and a screenshot of your manufacturer part properties from solidworks electrical? I could see if I get the same problem.
