2 Replies Latest reply on Aug 28, 2014 7:10 PM by Kevin Willis
    Remove fromparent+ from BOM description
    Jason Lackey
      I am getting the above mentioned issue when placing a BOM on a drawing, where the description shows up as "fromparent+SIDEPANEL".  Seems like there has to be a way for this not to show up, but I have not been able to find it in the forums or the help files.  If not, then this is a useless feature.  Thanks in advance.
      Jason
        • Re: Remove fromparent+ from BOM description
          Myles Bryning
          Is the item that is not displaying correctly a mirrored part at all? There are a few bug reports in the knowledge base on this, so it may not of been fixed when SW2012 was out.
            Kevin Willis
            I've personally run into this same issue, and while I haven't fully investigated the problem, I may be able to help. As Myles said, your part is likely a mirror, at least that's how this error appeared for me. I think the problem may lie in Step 4 of the Mirror Components tool. In comparing between having the "Custom Properties" box checked vs. unchecked when creating the mirrored part, I found that with the box checked I would be unable to get rid of the "fromparent+" description, but when the box was unchecked, I was able to set the description to my own liking. Using the "Break link to original part" box may also be something to experiment with.
            - Kevin
