I am trying to fillet the mid line of the door and the corresponding edge of the forward and rear fender. I tried to make two variable fillets. First one being on the rear fender piece, the end towards the back of the model having a radius of 7mm and the end at the node to be 0mm. Second fillet would be on the front fender and mid door edges: 7mm towards the front, 3.5mm at the door edge, 0mm at the same node.
Both are not working and I do not know why.
I even tried a variable fillet on the bottom edge of the door (0mm at the corners of the rocker, 7mm at the door edges). Still no luck.
Can anyone help me with these issues? I attached the model.
forgot to attach model.
