Creating Multiple Bolt Connectors across Instances of the same Part
Question asked by Joshua Okrent on Aug 24, 2014
Latest reply on Aug 26, 2014 by Jared Conway
I have a structure that I need to simulate and it is comprised of several different members bolted together to create a frame. I want to know if there is a way to add bolted connectors without having to go through one by one since there are a lot of connections. I know if I use an Assembly Hole Series, I can get the bolt connector feature to propagate for all of the holes, but the Assembly Hole Series fails when I have multiple instances of the same part in the assembly, which is something I need.
Is there any other way to add many bolt connectors at once?
