4 Replies Latest reply on Aug 24, 2014 1:15 AM by Deepak Gupta
    How to access part parameters from assembly ?
    Sanya Shmidt
      Hello guys!
      Can someone give me a simple example please.
      Assembly document
           - FRONT_BEAM
           - REAR_BEAM
           etc....
      Need to know how to change FRONT_BEAM parameter ("DF_X_Offset@Sketch1") from an assembly level?
      For single part its easy,
      ' single part
      swApp = Application.SldWorks
      swModel = swApp.ActiveDoc
      swModel.Parameter("DF_X_Offset@Sketch1").SystemValue = DF_X_Offset * 0.0254
      but how I tell via code get FRONT_BEAM and change DF_X_Offset@Sketch1@FRONT_BEAM???
      Any help is appreciated.
      Thank you.
        • Re: How to access part parameters from assembly ?
          Deepak Gupta
          Add model type in the DF_X_Offset@Sketch1@FRONT_BEAM.PART
              Sanya Shmidt
              Thank you. I was almost there :-)
                Sanya Shmidt
                Deepak,
                Do you know how to access/change Custom properties of the component in the assembly?
                What is the syntax?
                swModel.CustomInfo("Description@SideBeam.sldprt") = "TEST" ???? WHat is the correct way?
                Thank you,
                Alex.
                    Deepak Gupta
                    Try/Use these codes as required:
                    Option Explicit
                        Dim swApp                        As SldWorks.SldWorks
                        Dim swModel                     As SldWorks.ModelDoc2
                        Dim swCompModel            As SldWorks.ModelDoc2
                        Dim swSelMgr                   As SldWorks.SelectionMgr
                        Dim swComp                     As SldWorks.Component2
                        Dim value                          As String
                        Set swModel = swApp.ActiveDoc
                        Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
                        Set swCompModel = swComp.GetModelDoc
                        swCompModel.AddCustomInfo3 swCompModel.GetActiveConfiguration.Name, FieldName, FieldType, FieldValue 'To add configuration specific property
                        value = swCompModel.CustomInfo2(swCompModel.GetActiveConfiguration.Name, "Property Name Here") 'To get configuration specific property
                        Debug.Print value
                        swCompModel.CustomInfo2(swCompModel.GetActiveConfiguration.Name, "Property Name Here") = "Value Here" 'To change configuration specific property
                        'swCompModel.AddCustomInfo2 FieldName, FieldType, FieldValue 'To add custom property
                        value = swCompModel.CustomInfo("Property Name Here") 'To get custom property
                        Debug.Print value
                        swCompModel.CustomInfo("Property Name Here") = "Value Here" 'To change custom property
                        swModel.ClearSelection2 True
