Trying to create a helical pattern on a sphere. Typically for something on a cylinder using a curve driven pattern the face normal is constant, but in the case of a sphere the face normal is constantly changing. Any thoughts on how to create a curve driven pattern on sphere, keeping the features normal to the sphere?
Any help is appreciated.
Scott
Create the helix with varying dia/pitch and use than for the curve driven pattern.
OR
use the method suggest here Rectangle Spring by TON-MODIFY - YouTube Use the sphere and helix to create a 3d sketch around the sphere. And then use that for pattern.
