12 Replies Latest reply on Aug 29, 2014 8:23 PM by Sanya Shmidt
    How to catch if SolidWorks was closed
    Sanya Shmidt
      Hello guys!
      What would be the correct way to catch if user closed SolidWorks application.
      I use the following code when starting my app.
      If SeeIfSWRunning() <> True Then Me.Close()
      ' see if SolidWorks is running or not
          Public Function SeeIfSWRunning() As Boolean
              Dim p() As Process
              p = Process.GetProcessesByName("SLDWORKS")
              If p.Count > 0 Then
                  'MessageBox.Show("Running")
                  Return True
              Else
                  MessageBox.Show("SolidWorks is not running on this computer. Please start it prior to use this app.", TPCMessage, MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
                  swApp = Nothing
                  Return False
      Lets say user accidentally closed application in the middle of design and then clicked button on my app to open the template for instance...
          ' opens a template
          Private Sub btn_OpenTemplate_Click(sender As Object, e As EventArgs) Handles btn_OpenTemplate.Click
              If SeeIfSWRunning() <> True Then Exit Sub
              Part = swApp.NewDocument(Template, 0, 0, 0)
      Thats where I`m getting error....
      An unhandled exception of type 'System.Runtime.InteropServices.COMException
      I noticed that there are a few process by SW that starts with SLDWORKS
      - this is when SW is open
      - this is when SW is closed
      Is there a another way to check this?
      Thank you,
      Alex.
        • Re: How to catch if SolidWorks was closed
          Adam Hoffman
          Are you using Visual Studio and writing this as a stand alone exe?
              Sanya Shmidt
              yes. Using VB 2012
                  Adam Hoffman
                  This is what I use:
                  swApp = System.Runtime.InteropServices.Marshal.GetActiveObject("SldWorks.Application")
                  If swApp Is Nothing Then
                     MessageBox.Show("Error Connecting To SolidWorks!", _
                                     "SolidWorks Connection Error", _
                                     MessageBoxButtons.OK, MessageBoxIcon.Error)
                     Application.Exit()
                     End
                  Then periodically throughout the program, I use the above if statement to double-check the swApp variable.
                  If the possibility of more than one instance of SolidWorks to be open is possible, then I would go with Ivana's route.
                      Sanya Shmidt
                      Adam,
                      for some reason shutting down SW is not killing the process sldworks_fs thats where the issue is i believe.
                      follow the link to see the video.... Not sure what I`m doing wrong. It does same thing if I use your code above.
                      https://dl.dropboxusercontent.com/u/23443066/SW2014_issues.wmv
                          Adam Hoffman
                          Ok, after watching the video I think I have a better understanding of what's happening. You are closing SolidWorks and not just the part document before clicking the "Open Template" button for the second time. But if you click the button before SolidWorks has had a chance to finish the shut-down procedure, then your app is trying to tell a no longer valid process to do something which can result in the errors that you are seeing. Try closing just the document itself and not SolidWorks before clicking the "Open Template" button a second time.
                          Or you could possibly add a "Close Part" button to the app. The sldworks_fs.exe is an app that runs in the background if SolidWorks is installed on your machine whether SolidWorks is opened or not. Not sure what it does exactly though. But I believe it is not what is causing your issue.
                            Ivana Kolin
                            if p.count > 0 then
                            remove true    <---- remove this row
                            else
                            and if even that is not enough then you can try this :
                                Private Shared Function getSwApp(silent As Boolean) As SldWorks
                                    ' check how many solidworks instances are running :
                                    Dim myProcess As Process = Nothing
                                    Dim iCountSw As Integer = 0
                                    For Each process2 As Process In Process.GetProcessesByName("SLDWORKS")
                                        ' check if MainWindowHandle is created, otherwise SolidWorks is not ready yet
                                        ' and the GetObject in getSldWorksObject will fail
                                        If process2.MainWindowHandle <> IntPtr.Zero Then
                                            myProcess = process2
                                            iCountSw += 1
                                    Next
                                    If iCountSw > 1 Then
                                        If silent Then
                                            Return Nothing
                                        Else
                                            Throw New ApplicationException("SolidWorks has been started multiple times.")
                                    ElseIf iCountSw = 1 Then
                                        ' this is ok
                                    Else
                                        If silent Then
                                            Return Nothing
                                        Else
                                            Throw New ApplicationException("SolidWorks is not started.")
                                    If myProcess IsNot Nothing AndAlso myProcess.HasExited Then
                                        MsgBox(myProcess.ExitTime)
                                        Throw New ApplicationException("SolidWorks is exiting.")
                                    ' get application :
                                    Dim swApp As SldWorks = getSldWorksObject()
                                        If silent Then
                                            Return Nothing
                                        Else
                                            Throw New ApplicationException("An instance of SolidWorks could not be retrieved.")
                                    Try
                                        If swApp.Visible Then ' generates error during solidworks exit
                                    Catch ex As Exception
                                        If silent Then
                                            Return Nothing
                                        Else
                                            Throw
                                    End Try
                                    Return swApp
                                End Function
                                Private Shared Function getSldWorksObject() As SldWorks
                                    Try
                                        Return GetObject(, "SldWorks.Application") ' CType(Runtime.InteropServices.Marshal.GetActiveObject("SldWorks.Application"), sldworks.SldWorks)
                                        Return Nothing
                                    End Try
                                End Function
                      Ivana Kolin
                      we are using this
                      Private Shared Function getSwApp(silent As Boolean) As sldworks.SldWorks
                              For Each process2 As Diagnostics.Process In Diagnostics.Process.GetProcessesByName("SLDWORKS")
                                      iCountSw += 1
                              Next
                                  If silent Then
                                      Return Nothing
                                  Else
                                  ' this is ok
                              Else
                                  If silent Then
                                      Return Nothing
                                  Else
                              ' get application :
                              Dim swApp As sldworks.SldWorks = getSldWorksObject()
                                  If silent Then
                                      Return Nothing
                                  Else
                              Return swApp
                          End Function
                          Private Shared Function getSldWorksObject() As sldworks.SldWorks
                              Try
                                  Return Nothing
                              End Try
                          End Function
