Good morning all,
Whilst creating a weldment in sw 14 ive noticed a lot of options are missing in the properties/summary info/property name section.
part number
revision
finish ect ect
now when i open property manager the propety name section is completely blank, nothing to select at all. Ive attached a screen shot, many thanks in advance
You need to add it under Custom Property File and not weldment property file (still confused as why I suggested that you in the first place, really sorry for that).
The file won't appear as folder. You just need to select the folder in which the file has been copied. And then you would see the properties in the drop down menu when adding properties to models.
