3 Replies Latest reply on Aug 29, 2014 1:54 AM by Yong Ning
    traverse Sketch → How to get "Arc1@Sketch" ?
    Yong Ning
      macro recorded → result.
      boolstatus = Part.Extension.SelectByID2("Arc1@Sketch", "EXTSKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
      Traverse Sketch → gettype
      Private Sub ll1()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
          Set SwApp = Application.SldWorks
          Set SwModel = SwApp.ActiveDoc
        Dim SwSelMgr As SelectionMgr, SwFeat As Feature
          Set SwSelMgr = SwModel.SelectionManager
          Set SwFeat = SwSelMgr.GetSelectedObject5(1)
        Dim SwSketch As Sketch, SkSegArr, SkSeg As SketchSegment
          Set SwSketch = SwFeat.GetSpecificFeature
          SkSegArr = SwSketch.GetSketchSegments
          For ii = 0 To UBound(SkSegArr)
            Set SkSeg = SkSegArr(ii)
            Debug.Print SkSeg.GetType, Round(SkSeg.GetLength, 6)
            SkSeg.Select2 True, 1
          Next
      Help me
      Traversing sketch → How to get "Arc1@Sketch" style.
        • Re: traverse Sketch → How to get "Arc1@Sketch" ?
          Yong Ning
          Have  "Line1@Sketch1"→ SelectByID2 "Line1@Sketch1" → SketchSegment
          Help me
          How to get "Line1@Sketch1" From SketchSegment
          Private Sub llll()
            Dim swModel As ModelDoc2, swSelMgr As SelectionMgr
              Set swModel = Application.SldWorks.ActiveDoc
            Dim SwSeg As SketchSegment, SegLine As SketchLine, Ss 'As Variant
              swModel.Extension.SelectByID2 "Line1@Sketch1", "EXTSKETCHSEGMENT", 0, 0, 0, False, 1, Nothing, 0
              Debug.Print "SelType      = " & swSelMgr.GetSelectedObjectType2(1)
              Set SwSeg = swSelMgr.GetSelectedObject2(1)
                                            ' →  How to get the  "Line1@Sketch1"
              Debug.Print SwSeg.GetLength
              Ivana Kolin
              Dim vId  As Variant
                  vId = SwSeg.GetID
                  Dim swsk As SldWorks.Sketch
                  Set swsk = SwSeg.GetSketch
                  Select Case SwSeg.GetType
                      Case swSketchARC
                      Debug.Print "Arc" & vId(1) & "@" & swsk.Name
                      Case swSketchELLIPSE
                      Debug.Print "Ellipse" & vId(1) & "@" & swsk.Name
                      Case swSketchLINE
                      Debug.Print "Line" & vId(1) & "@" & swsk.Name
                      Case swSketchPARABOLA
                      Debug.Print "Parabola" & vId(1) & "@" & swsk.Name
                      Case swSketchSPLINE
                      Debug.Print "Spline" & vId(1) & "@" & swsk.Name
                      Case swSketchTEXT
                      Debug.Print "Text" & vId(1) & "@" & swsk.Name
                  End Select
                  Yong Ning
                  Thanks your key code → GetID(1)
                  Private Sub ll1()
                    Dim SwSelMgr As SelectionMgr, SwFeat As Feature, gID
                        gID = SkSeg.GetID(1)
                        Select Case SkSeg.GetType
                            Case swSketchARC
                               Debug.Print "Arc" & gID & "@" & SwSketch.Name
                               Debug.Print "Ellipse" & gID & "@" & SwSketch.Name
                            Case swSketchLINE
                               Debug.Print "Line" & gID & "@" & SwSketch.Name
                               Debug.Print "Parabola" & gID & "@" & SwSketch.Name
                            Case swSketchSPLINE
                               Debug.Print "Spline" & gID & "@" & SwSketch.Name
                            Case swSketchTEXT
                               Debug.Print "Text" & gID & "@" & SwSketch.Name
                        End Select
                      Next
