Change component reference not working
Question asked by Wasim Ahmed on Aug 21, 2014
In an assembly, I have used this code for changing component reference............
HRESULT SetConFig(IModelDoc2 *p_moddoc, IModelDocExtension *p_modextn, CComBSTR &Name, CComBSTR &type, CComBSTR &Config)
  // Function Sets the Configuration of the component
  //Parameters : ModelDoc, Extension , Name of component, type of component, Configuration to set
  //Discription: Sets the config
  ASSERT(p_moddoc && p_modextn);
  if (!p_moddoc|| !p_modextn)
  return E_FAIL;
  VARIANT_BOOL Status;
  HRESULT hr = p_modextn ->SelectByID2(Name, type, 0.0, 0.0, 0.0 ,VARIANT_FALSE, 0, NULL, 0, &Status);
  if(FAILED(hr)) return hr;
  CComPtr<ISelectionMgr> ip_SelMgr;
  hr = p_moddoc->get_ISelectionManager(&ip_SelMgr);
  if (FAILED(hr)||!ip_SelMgr) return E_FAIL;
  long l_Ind=1,l_Mk=-1;
  CComPtr<IDispatch> ip_Sel_obj;
  hr = ip_SelMgr->GetSelectedObject6(l_Ind,l_Mk,&ip_Sel_obj);
  ASSERT(ip_Sel_obj);
  if (FAILED(hr) || !ip_Sel_obj) return E_FAIL;
  CComPtr<IComponent2> Sel_Comp;
  hr = ip_Sel_obj->QueryInterface(&Sel_Comp);
  if (FAILED(hr) || !Sel_Comp) return E_FAIL;
  CComBSTR bst_CompConfig;
  hr = Sel_Comp->get_ReferencedConfiguration(&bst_CompConfig);
  if (FAILED(hr)) return E_FAIL;
  hr = Sel_Comp->put_ReferencedConfiguration(Config);
  VARIANT_BOOL b_Stat;
  hr = p_moddoc->EditRebuild3(&b_Stat);
  return S_OK;
It works for a few components and fails for some, when it fails i have to replace the component and then it works....Plz help
