How to import the file into the composer: (which is correct option?)
- Export: File save As .smg from solid works.
- Import: File open from composer, select the solid works file and with import profile is solid works (default)
- Import: File open from composer, select the solid works file and with import profile is custom
Both processes are correct. In the first example, the SOLIDWORKS Composer Add-In is using the Default Document Properties that you have saved to the Registry. In the second example, if you simply open the file directly into SOLIDWORKS Composer, the sames settings are used.
-Earl
