I have created an assembly using global variables & other equations which uses result of some other equations.
As I want to check whether I have given correct equation/ references, I want the dimensions to be displayed in assembly.
So I switched dimensions by right clicking on annotation tab & switching on Feature Dimensions.
But the dimensions I can see shows evaluated value. I want to display an equation instead of result, so that I can check the equations all at once.
Is it possible to display equation instead of evaluated result in a dimension??
Thanks in Advance,
Best Regards,
Nandkishore
Please excuse me if I'm answering the wrong question...I think this is what you need..you should be able to click on the symbol just to the left of the dimension.
Good luck!
