If the file exists it copies the file to a folder in the user's c drive. To do this in the past we used DIR to check the directory. However, since upgrading to and implementing EPDM this no longer works. I have tried using the filesystem object but this also does not work. Can someone please assist me in creating a code line in my macro to do this. Here is the code as it currently stands.
For i = j To j + Selection.Count - 1
'Do While ActiveSheet.Cells(i, 2) <> ""
If fsFileSystem.FileExists(PDFfilelocation & Trim(ActiveSheet.Cells(i, 2)) & ".pdf") Then
If i = 2 Then
PDFFName = "TL_" & Trim(ActiveSheet.Cells(i, 2)) & ".pdf"
Else
PDFFName = Trim(ActiveSheet.Cells(i, 2)) & ".pdf"
FileCopy PDFfilelocation & Trim(ActiveSheet.Cells(i, 2)) & ".pdf", "c:\print\pdf\" & PDFFName ' & " " & Trim(ThisForm.txtfrev.Text)
Else
'MsgBox "There is no PDF for " & Trim(ThisForm.txtfpartno.Text) & " " & Trim(ThisForm.txtfrev.Text)
Open "c:\print\PDF\notfound.txt" For Append As #1
Print #1, Trim(ActiveSheet.Cells(i, 2)) & ".pdf" '& " " & Trim(ThisForm.txtbom_rev.Text)
Close #1
DWGFName = Trim(ActiveSheet.Cells(i, 2)) & ".dwg"
If i = 2 Then
DWGFName = "TL_" & Trim(ActiveSheet.Cells(i, 2)) & ".dwg"
'Mid(DWGFName, Len(DWGFName) - 2, 3) = "DWG"
If fsFileSystem.FileExists(DWGFileLocation & Trim(ActiveSheet.Cells(i, 2)) & ".dwg") Then
FileCopy DWGFileLocation & Trim(ActiveSheet.Cells(i, 2)) & ".dwg", "c:\print\dwg\" & DWGFName '& " " & Trim(ThisForm.txtbom_rev.Text)
Else
'MsgBox "There is no DWG for " & Trim(ThisForm.txtfpartno.Text) & " " & Trim(ThisForm.txtfrev.Text)
Open "c:\print\DWG\notfound.txt" For Append As #1
Print #1, Trim(ActiveSheet.Cells(i, 2)) & ".dwg" '& " " & Trim(ThisForm.txtfrev.Text)
Close #1
'GetSA_PDFs Trim(ActiveSheet.Cells(i, 2)) ', Trim(ThisForm.txtbom_rev.Text)
'i = i + 1
Next i
'Loop
MsgBox "DONE!" & vbCrLf & vbCrLf & "The files were copied to c:\print." & vbCrLf & "Please see the notfound.txt file for drawings that were not found."
The
ActiveSheet.Cells(I,2) contain the part name which would be the file name in the vault. The PDFfilelocation is the directory path where the files are located on the c drive in the vault.
