KWKen Whitcher19/08/2014
I need to offset some lines & curves on the face of a solid object.
Without having to go back into the sketch mode, it is possible to project these over, while in the model?
Once the lines & curves are projected onto the model, I figure I'd offset them, then make my extruded cut.
INVENTOR allows you to do this, by using a feature called "Project Geometry".
This allows you to project lines & curves.
Does SOLIDWORKS have a similar feature?
