ReplaceViewModel(IDrawingDoc) not working
Question asked by Edgar Quintana on Aug 19, 2014
Latest reply on May 25, 2017 by Di Anne
The example in SW API help is not doing what is supposed to do. I 'm assuming that the API call is not functioning correctly. Can anybody run this macro and get the correct output?
This example shows how to replace a model in drawing views.
' Preconditions:
' 1. Open: install_dir\samples\tutorial\api\assem20.slddrw.
' 2. Ensure that the specified replacement model exists.
' Postconditions: The specified component in Drawing View1 is replaced
' with the specified model.
' NOTE: Because the model is used elsewhere, do not save changes
' when closing it.
Dim Part As SldWorks.ModelDoc2
Dim draw As SldWorks.DrawingDoc
Dim selMgr As SldWorks.SelectionMgr
Dim vViews(0) As Variant
Dim vInstances(0) As Variant
Dim boolstatus As Boolean
Option Explicit
    Set Part = swApp.ActiveDoc
    Set draw = Part
    boolstatus = Part.ActivateView("Drawing View1")
    ' Select the view in which to replace the model
    boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
    Set selMgr = Part.SelectionManager
    Set vViews(0) = selMgr.GetSelectedObject6(1, -1)
    ' Select the instance of the model to replace
    boolstatus = Part.Extension.SelectByID2("Assem20-3@Drawing View1/block20-1@assem20", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
    Set vInstances(0) = selMgr.GetSelectedObject6(1, -1)
    boolstatus = draw.ReplaceViewModel("C:\Program Files\SolidWorks Corp\SolidWorks\samples\tutorial\api\bagel.sldprt", vViews, vInstances)
